- Apr 10, 2018
- 5,538
- Plaster
- CircuPool RJ-45
Just to confirm, you did you turn off your SWG overnight between the OCLTs? If so, great news. No need to do another OCLT.
Here's an example of how one trichlor tablet will effect chemistry in your small pool:
When the sun hits the pool, UV will start to burn off FC. This is why you should increase FC to target level (liquid chlorine). Use the SWG to maintain FC. Your goal is set SWG output to match daily FC loss, usually between 2-4 ppm per day. You never want to fall below min level for FC.
Add salt.
Test CYA and work on increasing to (at least) the minimum recommended level for a SWG pool. Your SWG will not have to work as hard as the CYA will reduce FC loss as while your SWG is generating during the day. As you add CYA, also use liquid chlorine to bump FC up to the new target level (FC/CYA Levels). On the chart, make sure you click on the SWG tab on top.
Trichlor and dichlor each add chlorine to the pool, just as liquid chlorine does. Liquid adds water and salt as a byproduct. The two solid forms of chlorine add CYA (stabilizer). It okay to use trichlor and dichlor if you're also trying to increase CYA level. These chemicals are acidic and will lower pH (which you don't need) and can bleach the vinyl surface. We recommend plain, scentless, non-splashless, liquid chlorine (no additives) to supplement FC levels.I noticed in the swcg manual that I should use a chemical based on Trichloro-s-triazinetrione or sodium dichloro-s-triazinetrione dihydrate instead
Increase pH to recommended level before swimming.1) Raise ph.
2) Use SWCG today to get FC up to target and keep it there. (Since there's no chlorine loss, should I still add chlorine at this point? Headed out today to try and find correct product.)
4) Add salt
4) Test CYA and increase to target, if needed.
Add salt.
