Hello,
We are trying to get our pool open for the season and I am having issues with some of my chemistries.
I started with a couple rounds of SLAM (1st w/ bleach, 2nd w/ trichlor) as my water was a bit green and murky. Now that it is clear (current FC 1.0-I am waiting on testing my CYA as I only have enough left for one more test and am waiting on more reagent), I am trying to get my Alk & pH taken care of before working on raising the FC levels.
Initially, my Alk was 180 and pH was 7.6. Since trying to drop my Alk using Alkaminus by Utikem (Sodium bisulfate 93.3%/Sodium sulfate 6.7%), my Alk is down to 140 and the pH is ~6.8 (slightly more yellow than the 7.0 color block on my measuring tube). I tested my hose water to know what I am adding (Alk: 290, pH ~6.6 as it is slightly more yellow than where the pool water tested). I know I can use an aerator/fountain to bring up the pH, but I didn't know if there is something more I should/could be doing??
Thank you!
Thank you!
