help with water flow for a o-ring change
shirl1128
15
Ontario, ny
so I have been fighting a air sucking problem all last season (live in ny) and thought it was the new cartridge filter we put in but the read about it have to be from skimmer to pump. so I flex sealed everything even though i didn't see any leaks. we have a older pump and so we bought a new one this season and after a day running the filter is under pressure and we are blowing bubbles again well this year i noticed water leaking from the handle of the jandy 3 way valve, and I have learned that there is a o-ring set i can replace all great, buttt........ the hose from bottom main drain has no shut off. im reaching out to see what others here have done or any ideas on how to stop the flow while I change the o-rings out.
we have a 21' round above ground and we both cant stay under to unscrew cover.
