- Jun 18, 2021
- 51
- Vinyl
- Intex Krystal Clear
Hi everyone!
Thank you, in advance, for your help!
I have a 1,718 gallon above-ground Intex pool, with plans to upgrade to a large pool in the future.
Last year, we did chlorine, and this year, we'd like to switch to salt! My toddler has eczema, so we think this will be a nice change for her.
Intex has a few super affordable solutions for salt water systems, but their pricing makes me want to get the larger one...but I don't know if that would be detrimental.
As we experienced last year before our pump upgrade, Intex is known to offer systems that are too small for the matching pool (such as the pumps that come with the above ground pools).
So, I'm wondering if I should err on the side of caution and get the SWG whose range goes up to larger size pools.
Could I get some help and understanding behind which SWG to purchase?
Our Pool:
Our Pool:
- Gallons: 1,718
- Size: 12' circle, 36" tall.
- Material: Vinyl with metal pole frame
- Filtration: Sand
- Pump Flow: 2,400 GPH
- Inlets: 2
- Outlets: 2
- Accessories that leverage pump: 1 fountain
- Best CYA for our location with Chlorine last year: 60
- Requires a filter pump with a flow rate between 700-3,200 gph
- Chlorine output: 5g/hr
- 24 hr. auto-clock cycle
- Max pool size: up to 7,000 gallon
- Requires a filter pump with a flow rate between 700-3,200gph
- Chlorine output: 12g/hr
- Max pool size: up to 15,000 gallons
