Hi there,
I’ve been browsing similar posts and I suppose I just need support to know I’m on the right track.
I’ve just completed day 7 of SLAM. On 4 of those days (including first 3 days), I was off work and checked levels and added chlorine 6-7 times a day. On 3 days I worked and could only do 4 times a day.
90% of the visible algae cleared up in the first 48 hr but there has been a plateau and I have observed the same amount accumulating every day for about the last 4 days.
There is consistently a 2-4 point drop in my Cl overnight, as expected with visible algae.
I’m using 10% LQ and following Pool Math for dosing instructions. I’m getting in to brush at almost every Cl check. Running the pump 24/7, as I always have. CYA is 50.
My stairs are hollow and removable. I spray bleached them at the beginning. Since then I have brushed them and drained them several times a day, letting them refill with the high Cl- SLAM water.
I know SLAM is supposed to be safe for vinyl pools but I’m worried that my liner is looking so bleached. I’m worried that I haven’t seen any progress since the early days.
I mentioned in my introductory post that I have a tree shading most of my pool which daily adds organic debris including leaves and lots of caterpillar and animal droppings. My water temp averages about 93 degrees and runs through a solar heating system. The response to that post said thesethings should not influence the success of my SLAM.
MY water was clear and balanced at the start, not swampy and gross, so I was not expecting it to take this long.
So, any recommendations, or just stay the course? Apparently, there is no such thing as a SLAM failure but I am feeling gloomy.
