OK, so I need some help. I took my light fixture out of the side of the pool and it's full of water...so that's obviously a problem. Also, my GFI on the side of the house that the light terminates at is flashing, which says that means it needs to be replaced.
What would you do?
1. Try to dry out the fixture and re-install?
2. Replace the fixture and just start over? (this is probably the option I'm leaning towards)
Here are some pics of my existing fixture. How do I tell which model/voltage it is so I know what to replace it with?
What would you do?
