About to pull what is left of my hair out. I've read many TFP threads on staining and it appears there are varying opinions on what to do for each poster. I would like to see the pros thoughts on what to do before wasting more money and time.
Last October we had the plaster acid washed because of of a reddish brown staining and a dark grey/black streaking. Acid washing cleaned the plaster to a like new look. We had a long reddish brown streak during refilling the pool where the water hose was located. Muriatic acid easily removed the streak where it was above the filling water level. It did nothing below the water level since it was diluted by the water.
We are on well water that is high in iron. We have to have a pump injecting chlorine into the tank when the pump runs. Without the injector, the water initially has a metallic smell and then it turns to a rotten egg smell. Our plumbing has a the same reddish brown discoloration inside the pipes. We also have a whole house filter treating the water being fed to the house. The pool is filled with filtered water, but even then the water isn't completely "clean". You don't want to see our water filter after a few weeks!
After the acid wash and refill we converted to the TFP chemical method. Slowly the staining and streaks returned. Now we have multiple large areas of reddish brown staining and the streaking has returned.
Testing results from yesterday
FC 6.5
CC 0
PH 7.2
TA 90
CH 300
CYA 30
Temp 95
Borates 60
CSI -0.18
FC 6.5
CC 0
PH 7.2
TA 90
CH 300
CYA 30
Temp 95
Borates 60
CSI -0.18
