Hello and thank you for taking the time to read this.
I saw lots of other posts about Fiberglass pools bowing, but mine is a bit unique and I was hoping to get some advice.
My inground Fiberglass pool was already installed when I purchased my home. I'm guessing the pool is in the neighborhood of 15 years old.
I recently (Within the last 3 days) Hired someone to come and apply a re-coat of Aquaguard 5000 to the surface of the pool.
In order to do so, they had to drain the pool. The pool does have a separate sump to control groundwater and the contractor ensured they kept a pump in the sump hole to keep the water drained.
However, now that the work is complete and the pool is filled, I have two noticeable outward budges in my pool, at the deep end, almost directly across from each other.
The pool is now filled with water, and the contractor is trying to tell me the buldes were there before. But I have spent enough time in this pool to know there were no buldges in it before he drained it and re-filled it.
I don't think this contactor is dishonest, but at this point I'm not sure about his skill set to address this issue.
So I'm asking what my options could be to fix the bulges short of breaking the concrete and re-digging around the pool?
Or will are these bulges' just an aesthetic problem and won't hurt the pool structure?
The odds of him doing any major work to fix the problem are slim.
Thank you
Thank you
