I have a 20 x 40 inground vinyl lined steel sided pool. It is around 10 years old I think. We bought house last year. The previous owners never winterized and we live in northern Arkansas and experience hard freezes. They would just drain to below return jets but no plugging or blowing out main drain.
This is our second summer. The pool has had several issues. We have pretty much rebuilt the filter because of sand leaking back in. We concentrated so heavily on that issue that we didn’t notice the leak. Last year it leaked about 1/2 inch to 3/4 inch per day. But it was a hot dry summer so I kind of ignored it. This summer it has been leaking up to an inch a day and we noticed a puddle behind the pool. It’s built on a slope. I can see a small hole in one skimmer basket where the pipe meets the opening. The other skimmer basket leaks also. I did a dye test and can see dye being sucked in.
The liner will probably be good a few more years. I’ve been researching online and am considering using that stop leak liquid. But I’m fearful of messing up my equipment as I have nearly a thousand in the filter. Has anyone tried using the fix a leak? If so, any advice? My hope is to put off digging until I replace the liner.
It has two skimmers, a main drain, two return jets and a return for booster pump.
