I just moved into a new house with pool and I'm trying to make sense of the crazy chemistry it has going on. I was able to talk to the pool cleaner that the last owner was using and he told me that the previous owner refused to partially drain and refill the pool to reduce the high CYA for whatever reason. He also said it's very common in San Antonio for the pools to have both high CYA and FC numbers since hardly anyone uses liquid chlorine. I've removed all sources of chlorine and tested it today with my K2006 kit. I'm getting FC of around 17.6 ppm and CYA that's way off the gauge. I've attached pics. These readings were after me draining to just below the skimmer and refilling back up, I couldn't figure out how to pump any more water out without the pump running out of water. That's another issue
