HI everyone. It's been awhile since I've been on the Forums. Several medical issues and then last season I had to.have my pool completely remodeled. Not.sure thr previous owner hired a reptuble company or.a.fly by night to install the pool but they went out of business shortly after instal according to the neighbor. The attached the skimmers the patio and NOT the pool itself. Of course this caused both skimmers to crack. Plus it was a saltwater pool and had steel plat.as the top of the groto and waterfall that.was so rusted I'm surprised it.didnt collapse into the pool. Changed everything over to clorine and had a 2"?? Sand filter installed using glass beads as the medium.
Problem is now I have forgotten how to program the VSP pump. It will be controlled by an Easy Touch system (old one) won't go to flow, only to VS. I know the pump has an external control system with some sittings but not sure if I need to set any of them or just control it with the Easy touch? If I need to set up that part of the pump ( I think it 4 settings what do I set up and what RPMs do I use. BTW F circuit 1 is set up on the Easy touch as pool high. I think the pump installer did that on purpose so I could some how run the pool fast for a few hours to help mix chemicals and clean/skim. Then set the "pool" setting at a lower speed. When using the settings intiliflow pump 1 I have something like 8 placesitting. Can I set up more than one pool seed, but then how do you control the time etc under schedule? Finally, what are the recommended RPMs for a 20k pool for, pool, pool& spa, cleaner' and waterfall? I know some like the waterfall is choice but others ar critical. Sorry for being so long but was on hold with Pentair for.over an hour and finally hung up!
Thanks in advance for any insite and help.
