Help with 2 speed pump installation.
notthepoolman
1
florida
Installed my 2 speed replacement pump. Running T104 as an in/off switch and the a T106 for hi/low. The motor only runs at high mode. It also gets hot to the touch in 20min.
Note the new pump is supposed to be a direct replacement. 1.5HP SF 1.3. Replaced 2HP SF 1.0.
i attached pictures of the wiring.
Thanks for your help.
The wires need to be on the correct terminals.
_______________________
New.
A - Low
L1 - High
L2 - Common (Black).
Old. (Fill in the blank (?) with High, Low or Common).
Black - Common.
Red - ?
Blue. - ?
Not,
Leaving your two timers..
The left timer, pin 4 should go directly to the Common input of the pump.. (Appears to be a black wire)
The right timer, pin 3 (Red wire) should go to either the low or high input of the pump.
The right timer, pin 2 (Blue wire) should go to either the high or low input of the pump.
The problem for me, is that you do not show which pump pin is for the Common, Hi and Low inputs..
Reactions: JamesW
