- Mar 17, 2019
- 610
- Plaster
- CircuPool RJ-45 Plus
Hi,
Looking to see if I can tackle wiring a new Circupool RJ45 so that the SWG comes on when my pump comes on. I have very basic electrical skills and I'm not averse to calling in an electrician, but figured I'd leverage the good folks on this forum to see if the job is within my pay grade.
Attached are some pics of my electrical setup at the equipment pad.
I have a standard Intermatic timer box with the yellow wheel; however I no longer use the wheel because my 2-speed pump (hi/lo) has an electronic programmable timer built into it. The pump then gets wired to a breaker inside the electrical box containing the timer wheel. This box also houses a breaker for my water feature pump, and switches for my pool light and pump. There is also a 50 amp breaker at my main breaker box which controls the entire sub-panel at the equipment pad.
Given what you see in the attached, is this a pretty straightforward job that I could be walked through online?
Thanks!
Thanks!
