Hello everyone,
I'm a new pool owner and I've been taking poor advice from the internet (purchasing test strips that one site recommended-bad I know that now) and then followed that up with taking my water samples to Leslie's. After my 3rd analysis at Leslie's and my pool not getting any clearer...I found TFP. I finally purchased a TF100 kit from Dave/Rebecca and have real numbers for you.
Question- when is the best time to take a sample from the pool? (i.e. after the filter has been running for 4 hours, does it matter?)
Today's reading 1.5hrs after filter started using the TF100 kit.
pH 7.5
FC 2.5
TC 3.0
CH 300ppm
TA 260
CYA 90ppm
HISTORY
We had heavy rainfall a few months ago/March and I could see fine dirt particles were falling into the pool for days and I thought that all I needed to do was run the filter 24/7 and add clarifier (I've gone through 3 bottles already) but the pool wasn't crystal clear, I can see the drain but it's not completely clear. So I decided to take my water samples to Leslie's to see if they could tell me why.
1st reading (4/3) they said my CH was low at 130 and had me add Calcium, they also told me my phosphate levels were off the charts at 2500 (yes stupid me believed them and purchased bottles and bottles of PhosFree) FC 4/CH 130/CYA 80/TA 110/pH 7.6
My 2nd water analysis 4/18 said that my CH was still low at 160 and to add more Calcium (I followed their printout of how much to add and in hindsight again...believing them I worry that maybe I added too much), my pH was high at 8 (and used their dry acid to bring it down) and again my phosphates were still high at 1500 (this time I didn't add more PhosFree) -FC 5/CH160/CYA60/TA100/pH8
My 3rd analysis was 2 days later 4/20 at a different location (just in case something shady was going on) and this time I get a CH reading of 270 but the guy said that it will probably keep climbing up since the calcium probably didn't dissolve fully yet and that the other leslie's employee should have told me to add less calcium instead of what the printout says. Anyways in 2 days my FC went from 5 to .5 so they told me to add Power Powder Plus (cal hypo) FC .5/CH270/CYA60/TA100/pH7.4
In the past 3 weeks since then, I've just been taking readings of my pool (using the test strips-I didn't have to TF100 kit until a couple of days ago) and adding cal hypo when I saw my chlorine levels were low - but everything else looked like it was within "ok" range (of the test strips)
NOW
plugging my numbers into the PoolMath...I'm worried that I have to drain 53% of my pool to lower CYA (and it was only 13% to bring CH down)
Anyone have advice as to what my next steps are?
Oh and I think I may have broken my solar controller panels but that's a separate issue that I will have to follow up on.
THANKS FOR YOUR HELP!
pH 7.5
FC 2.5
TC 3.0
CH 300ppm
TA 260
CYA 90ppm
HISTORY
NOW
