Please help.........I vacuum (using battery operated handheld vacuum) to remove any debris that may be at the bottom of the pool and to brush the bottom and sides of the pool. The water in the pool is crystal clear. After the sand filter has been running there's black sediment on the bottom of the pool. I have tried: vacuuming to waste, zeofiber, changed the sand in the 3 year old sand filter, and purchased a new pump. Nothing has worked! I don't know what to try next.
