Thank you all!!!! Ajw22 indicated info on existing equipment etc. would be helpful. I have attached some pictures of existing equipment, pool and decking as well as some preliminary notes on the landscaper's and pool proposals.
Outlined below are the upgrades we are considering thus far. I've separately pasted the one formal proposal we've received at the end. More than welcome any and all recommendations, thoughts, opinions!
- install new automatic pool cover
- re-finish pool interior. leaning towards grey plaster; although, we're considering pebbletech / diamond brite; would love to save costs here though.
- new tile, coping (ideally, coping will match the techobloc deck, see below)
- install new sunshelf - based on TFP feedback on other threads, leaning towards width of the pool with 6" step along the width (as this will be our main entrance). Sundeck proposed to be 7' long and 12.5" deep (welcome any thoughts on these dimensions and whether additional stairs / steps beyond the ledge are needed).
- install techobloc deck - travertina slab (we really like the grass / pavers look, and are considering this with a few inches of grass between pavers (in part due to size of the yard and deck expansion, we want to avoid concrete jungle look) if you have any opinions on grass and pavers).
- potentially install upgraded heater, as needed. We understand more efficient units are on the market. Currently we have gas, and we haven't used the heater much (in part, because we're afraid of the costs as our gas is billed bi-annually... curious if anyone has experience in verifying these estimates: Gas Swimming Pool Heaters | Department of Energy). All of this said, we understand the auto cover should help retain temperature / warm the pool as well. As it stands, we don't get as much use of the pool because the lot is so shaded and the pool is fairly cold except for a little over a month in the summer.
- install in-pool polaris pool cleaner. we currently have the F9550, but if we're doing everything else, we should really install this as well, correct?
- considering salt water conversion
Below are the specs from the existing quote we received (note the change from blue stone to techobloc deck). Curious if you think there is anything significant or notable missing.
1. DRAIN AND SECURE POOL FOR FOR THE FOLLOWING REPAIRS.
2. REMOVE AND HAUL AWAY DEEP END PORTION OF CONCRETE POOL DECK AND SIDE OF POOL DECK
FURTHEST FROM STONE RETAINING WALL. (SEE ATTACHED DRAWING)
3. PRESSURE TEST ALL SWIMMING POOL PLUMBING AND REPORT RESULTS TO OWNER/SIGNATORY.
4. PROVIDE OWNER/SIGNATORY WITH PRICES AND OPTIONS TO REPAIR OR REPLACE PLUMBING AS
NECESSARY.
5. PROVIDE AND INSTALL NEW OUTDOOR INTERMATIC DUAL TIME BOX WITH BUILT IN ELECTRICAL SUB PANEL
TO PROVIDE ELECTRICAL SUPPLY TO ALL SWIMMING POOL EQUIPMENT. NEW PANEL TO BE 50 AMPS.
6. PROVIDE AND INSTALL TWO (2) NEW SKIMMERS AS PER POOLSERVICE COMPANY SPECIFICATIONS FOR:
"REPLACEMENT OF SKIMMER(S)".
7. PROVIDE AND INSTALL TWO DRAINS WITH GRATES IN DEEP END FLOOR OF POOL THAT COMPLY WITH
ASME/ANSI A112.19.8-2007 AS OUTLINED IN THE VGB POOL AND SPA SAFETY ACT 2007.
8. PROVIDE AND INSTALL COMPLETE POLARIS PLUMBING LINE THROUGH THE SHELL OF THE POOL RUNNING
BACK TO THE FILTER EQUIPMENT. NEW POLARIS TO INCLUDE 3/4 HP PUMP AND POLARIS 280 POOL CLEANER.
9. PROVIDE AND INSTALL TWO (2) NEW DEEP END BENCHES IN EACH OF THE DEEP END CORNERS OF POOL .
10. PROVIDE AND INSTALL TWO NEW TANNING SHELVES IN EACH OF THE SHALLOW END CORNERS. EACH
TANNING SHELF TO BE APPROXIMATELY 7' X 7' AND NINE INCHES DEEP.
11. PROVIDE AND INSTALL NEW POOL STEPS BETWEEN THE TWO NEW TANNING SHELVES IN THE POOL.
12. NEW CORNER BENCHES, TANNING SHELVES, AND STEPS TO BE SHOT INTO PLACE USING GUNITE
(PNEUMATICALLY PROJECTED CONCRETE) AND BUILT AS PER INDUSTRY STANDARDS. NEW POOL INTERIOR
STRUCTURES TO BE BUILT SIMILAR AS ATTACHED DRAWING.
13. INSTALL NEW CONCRETE AUTO COVER BOX REINFORCED WITH STEEL BAR AND TIED INTO POOL SHELL AS
14. NEW COVER BOX TO HAVE NEW STAINLESS STEEL STONE LID BRACKETS TO SUPPORT NEW BLUE STONE
LID. NEW COVER BOX LID TO BE SAME STONES AS THE NEW COPING.
15. LOWER AND MODIFY THE DEEP END WALL AND TWO DEEP END CORNERS OF THE POOL TO ALLOW NEW
AUTO COVER FABRIC TO OPERATE CORRECTELY AND PASS OVER THEM.
16. BOTH SHALLOW END RADIUS CORNERS TO BE CONVERTED INTO A MITER CORNERS.
17. PROVIDE AND INSTALL ALL NEW POOL PERIMETER COPING AS PER ATTACHED POOLSERVICE COMPANY
SPECIFICATIONS FOR: "NEW COPING BAND INSTALLATION".
18. NEW COPING TO BE: 2" THICK, 14" WIDE, PREMIUM BLUE STONE
19. PROVIDE AND INSTALL ALL NEW POOL PERIMETER TILE BAND PER ATTACHED POOLSERVICE COMPANY
SPECIFICATIONS FOR: "TILE BAND REPLACEMENT OR INSTALLATION".
20. NEW TILE TO BE SIX INCH PERIMETER BAND USING STANDARD GRADE FROSTPROOF TILE. TWO DEEP END
CORNERS OF THE POOL TO BE TILED ON TOP USING SIMILAR COLOR TILE AS THE PERIMETER.
21. PROVIDE AND INSTALL NEW SAFE-T COVER T3 AUTOMATIC SWIMMING POOL COVER MECHANISM AS
MANUFACTURED BY COVER-POOLS, INC. INCLUDING: NEW DRIVE MECHANISM, PULLEYS, TRACK, ROPE
GUIDES, AND OWNER'S KIT.
22. PROVIDE AND INSTALL NEW SAFE-T COVER T3 REINFORCED VINYL FABRIC AS MANUFACTURED BY
COVER-POOLS, INC. INCLUDING: NEW ROPE AND LEADING EDGE BAR WITH GLIDERS.
23. PROVIDE AND INSTALL NEW WIRELESS TOUCH PAD WITHIN CLEAR SIGHT OF THE SWIMMING POOL.
24. INSTALL EXISTING WINTER COVER AS PER MANUFACTURERS INSTALLATION REQUIREMENTS.
25. PROVIDE AND INSTALL NEW POOL PLASTER PER ATTACHED POOLSERVICE COMPANY SPECIFICATIONS FOR:
"RE-PLASTERING OF SWIMMING POOLS".
26. PLASTER TYPE TO BE: RIVER-ROK
27. THIS PROPOSAL INCLUDES POST PLASTER BRUSHING AND CHEMICAL MAINTENANCE.
(SEE SECTION IV OF THE RE-PLASTERING SPECIFICATIONS)
28. PROVIDE AND INSTALL NEW CAULK IN POOL PERIMETER EXPANSION JOINT AS PER ATTACHED POOLSERVICE
COMPANY SPECIFICATIONS FOR "CAULKING".
29. BILLING SCHEDULE TO BE AS FOLLOWS:
A. DUE UPON ACCEPTANCE
B. DUE AFTER EXISTING TILE AND COPING ARE REMOVED
C. DUE AFTER NEW TANNING SHELVES AND STEPS ARE INSTALLED
D. DUE AFTER NEW TILE AND COPING ARE INSTALLED
E. DUE AFTER NEW COVER BOX AND DUAL DRAINS ARE INSTALLED
F. DUE AFTER NEW AUTO COVER MECHANISM IS INSTALLED
G.DUE AFTER POOL HAS BEEN PREPARED FOR NEW PLASTER
H. DUE UPON SUBSTANTIAL COMPLETION
Not so cynical. I think realistic.
Contractors have the brands they know and have experience with. Most don't like being taken out of their comfort zone. Especially complex pool automation. Expect any advice you get from contractors will reflect their bias and not be representative of the best in the market.
Pentair, Hayward, and Jandy are the big three and with integrated pool automation the automation, pump, and SWG comes from the same company. Then pick your filter and type of heater. After that it is what water features you want in a spa or pool.
