Welcome to TFP!
Sounds like a few things need to be addressed first:
- How are you testing your water? Which test kit specifically?
- An AA treatment only removes the staining, so the iron is still in the water. Shocking, or elevating the FC level exceptionally high, only causes the iron to react.
- We almost never recommend floc or clarifier. They can mess-up your filter media.
- Algaecides do nothing for iron
- Metal Free will only handle x-amount of iron, and a high FC level can lessen its effectiveness.
- If you are filling from a well, the iron will just come back unless you have a way to filter it out (i.e. polyfill).
If the green is clear and only related to the reaction between iron and chlorine, you could let the FC fall a bit and see if the green goes away. Also adjust the pH to 7.5 or slightly lower. If the green is tied to algae, then you 'll need to perform a
SLAM Process to remove algae. Removing algae must always done first before treating for metals.
