My saltwater generator has been saying low flow often. I cleaned the filter yesterday. I came out this morning, it says low flow and I feel little water coming out the return. I take things apart and keep turning the pump off and on looking for maybe something clogged, this didn't go too great cause it seemed like whatever I took off, when I turned the pump on it was a burst of pressure at 1st then the pressure would drop.
My pump/motor is an AquaPro APF100Pro. I think the pump prop must be worn out or wasted in some way and not creating the pressure it once had.
I probably broke it cause I know in the past I forgot to open a valve or 2 and it ran for a significant amount of time with water not being able to flow.
What do you guys think and is there anything I can do to test or confirm this?
edit. its not any clogged baskets, cause I have main drains as well and everything is open.
