The pump and Heater worked for about 2 days.
The heater itself is fine. Its just the pump... here are the symptoms
Turned on any mode (in this case egg timer, 2500 RPM set for 3 hours with a priming time of 5 minutes)
The Filter Pressure gauge jumps up to 20psi for a moment as the water is flowing and then down to 0.
Then It goes into its normal routine. Primes, water flow starts basket fills up and the LED completes priming and motor speed lowers from Priming at 3450 to 2500 RPM.
The issue is that its complete priming in under 3 minutes and the egg timer starts at 2500 RPM with zero to no water flow.
I attempted the following troubleshooting steps
- Checked all O rings and they are in good condition.
- Cleaned the filter out and back washed.
The odd part about the filter... i've opened it before to clean it in the past and when i opened it this time the water was still sitting on the bottom of the filter. It didnt drain.
Thoughts?
Thoughts?
