I got the Taylor K-2006 here are my numbers
Free chlorine 7.0 ppm
Combined 0
Ph 7.4
Alkalinity 90
Cya 80 (ugh)
Calcium hard 150
I had winterized with in the swim kit took cover off and pool was beautiful. I opened it before learning about Taylor k-2006 and stabilized chlorine. Thanks to the info here I quit using stabilized chlorine and am just using bleach and started using Taylor test instead of strips. When I opened my cya was 60 on strips but jumped up after shocking and chlorine tablets and got cloudy. It’s not super cloudy I can see the bottom but it is by no means clear. I am thinking of trying the alum (floc) to lower cya… I haven’t done SLAM because the number seems so high that I would need because of where my cya is at… my pool is just shy of 10,000 gallons above ground pool. Thank you so much!
Combined 0
Ph 7.4
Alkalinity 90
Cya 80 (ugh)
Calcium hard 150
