- May 3, 2007
- 16,974
- Plaster
- Hayward Aqua Rite (T-15)
Most of the IG single speed pumps are dual voltage but to simplify the wiring, two speeds are single voltage .
Also, the WFDS-24 is an up rated 1 HP and identical to the WFDS-3 which is a full rated 3/4 HP. Both are 115v.
I think the point JB was making is that the Superpump is a dual voltage pump and he was just trying to make sure it was actually wired for 115v and not 230v. Also, if you have a breaker panel at the pad, you should be able to wire a pump either way.
