Hi all,
Just replaced my SWG cell a week ago and my FC is a bit high as I'm being figuring out how to set it for my pool (moved from a ic-40 to an ic-60.
My water is excellent, super clear and no issues at all.
FC 10
PH 7.7
TA 100
CH 425
CYA 50 (I think it's actually closer to 60 I had to rush through this in the morning today)
Salt 4000
Fwiw I also tested for phosphates and that is zero.
All tests tone with Taylor and tf test kits.
I got a 42,000 gallon pool. Pool math says that 70lbs of boric acid should yield a ppm of borates of 35. I ordered 70 lbs of boric acid granular form from duda energy.
First of, does adding 70 lbs seem about right for my pool?
Second, should I try to lower the TA a bit before I add the boric acid?
My TA has been real stable around 100 for about a year or two and it's a real pain to lower it, but it you recommend that I take it down further first then I'll do it.
My objective is to stabilize PH so it increases more slowly. I hear the borax also makes the water silkier which is a nice secondary benefit.
Thoughts?
I don't really have a great way to test Bor levels once I've added it so i want to get a second set of eyes on it before I charge ahead. I have a automatic pool cover so once it's in the water it stays, I don't get diluted by rain and I have a bit of evap but not that much.
Thanks!
FC 10
PH 7.7
TA 100
CH 425
Salt 4000
Thoughts?
Thanks!
