Help in PA
Your FC is fine! Keep SLAM'ing the pool and don't let it go under your SLAM level.
Congrats on your new precious lil boy. I bet he is the sweetest!
You're making progress - the test results show that. You've only been at it for two days... now is the agonizing wait for the filter to clear things. Has the filter pressure been climbing?
Anything you can do to improve the circulation to get more of that suspended matter to the filter, the better. Brushing helps. If you have a vacuum that plugs into the skimmer, you can put that in the bottom of the pool and set it on its side to draw water from lower down.
Time to open a can of POP -- Pool Owner Patience.
