My water was nice and balanced. I screwed it up by making a few rookie mistakes in adding Borax. Oye!
1) I read that Borax stabilizes pH, but I did not know that it pretty much LOCKS it at the level it is when Borax is added.
2) This morning my pH was at .6 so I added .4 oz Dichlor at 11:40am. W/o testing pH first, I then added .8 oz of Baking Soda to raise my TA from 40 to 50. And again w/o testing either pH or TA, I added borax at 12:30pm. PoolMath told me to add 20 oz (by wt.) or 19 oz (by volume) of 20 Mule Team Borax. I always want to verify any weight to volume equivalences, so I used a measuring cup on my scale (tared to 0), then added Borax. When my two cup measurer was at 19 oz of volume, the scale showed only 13 oz by weight. I verified on a second (less accurate kitchen scale). Anyway, I put mixed the 19 oz volume/ 13 oz wt. of Borax into a bucket of spa water, stirred, then poured into spa. 15 mins later I tested for pH and it was very, very bright red. I have no idea how to guess how far above 8 that is, so I just called it 9.o in PoolMath.
Starting at 1:00pm, I started adding a sequence of doses of three doses of 20% Mur. Acid (1 oz, 1.2 oz, 2 oz.). The bright red pH color did not seem to budge. I started to wonder if somehow my only 6 week old 20 MA had lost its strength, even though that defies logic.
At 2:30pm, I opened my brand-new jug of 31.45% MA and added 1.5 oz. pH was still sky high.
AT 3:25pm, I decided to focus back to FC, as I had not checked it after adding the .4 oz of Dichlor at 11:40am. At 3:25pm FC was at 0.8, Oops. I added .4 oz of Dichlor. At 4:05pm I tested FC at 6.6, pH at ≈8.5, TA at 110.
At 4:30pm, back to adding more MA trying to drop pH, I added .8 oz 31.45% MA. 15 mins later, still ≈ 8.5 pH, so I added another 1.5 oz MA 31.45%.
At 5:15pm, FC was at 6.0, pH looked only slightly above 8.0, so I called that 8.1 pH.
I stopped adding repeated doses of MA and came to ask here if I should be doing something different from just continuing to add MA??
If I am to continue adding multiple MA doses, can I start making larger doses per addition? At some point might 'the next dose' of MA drop pH drastically all of a sudden? Or each additional dose drop pH approximately the same amount per addition?
