Hello,
I recently took over the care of my family’s pool. It is green, cloudy, and has thousands of tiny bug larvae swimming in it.
I ordered the wrong Taylor test kit which I am going to return, so I only have access to the test strips we already had which test FC, pH, and Alk.
My first reading was FC 0, Alk 0, pH <6.2.
I read somewhere on here (I can’t find the thread anymore) that I should fix the Alk first with soda ash until ~50, then fix the pH with borax, then fix the FC with bleach.
I added 6kg of soda ash and the following day my readings were FC 0, Alk ~40, pH <6.2.
My dad then suggested SLAMing the pool before finishing my other adjustments.
What do you recommend is the best course of action??
Thank you in advance for your help.
Edit: I’m not sure I added my signature correctly because I can’t see it on my post. Toronto, vinyl, 38000g, chlorine, sand filter, unsure about pump, older than 2000.
