Hi,
We are relatively new pool owners, and have had our fiberglass inground pool for two and a half summers. We have a very fine white sediment in our pool that sinks too the bottom when not in use. When cleaning or swimming, the sediment gets lifted up so that the pool water is almost totally opaque (can't see feet). There is also a film on the pool that is gritty, only under the water surface. Above is smooth. Is this a calcium imbalance? pH or alkalinity? Any advice on how to fix the problem?
Some possibly helpful info:
- Chlorinating with powdered chlorine one cup every second day, at home test says pH is fine and chlorine within upper limit (maybe high at times).
- Not green, no obvious algae problem
-No burning when swimming
-Sunlight until 2pm, then shade
-Glass filter medium
-Backwash window has difficulty becoming clear
-Location is southern Quebec
Thank you in advance!!!
