Hi folks,
Based on reading here and elsewhere, I've tried to setup my pentair screenlogic app config but wanted someone to double check and confirm a few things.
Photos of my equipment and settings are here : Pool equipment
Equipment/setup:
IntelliFlo pump with the SVRS option
PSL4 EasyTouch
Whisperflo pump - for waterfall
Gas heater
Settings and questions:
Anything else I'm missing ? Thanks again!!
Equipment/setup:
PSL4 EasyTouch
Gas heater
- Pool + spa connected (spillway) - pool water returns from spa and spills back into pool
- Waterfall
- In spa mode: spa water stays in spa
- Pool volume - about 20,000 gallon
- Electricity is cheaper during night and non-peak hours and since it’s winter (although we still get days with 70F in texas), I’ve set pool high to run at night and few small cycles of pool low during the day - total ~8 hours. In summer, I plan to run pool low during peak day/heat hours for total of about ~12-14 hours
- Q: Need to figure out what’s the turnover rate (20,000 gallon) so we can set RPM and duration correctly.
- Based on my reading, I’ve set ‘pool low’ to ‘pool’ circuit and left ‘pool high’ as a feature/generic (vs the opposite).
- In spa mode, I disabled ‘spa manual heat’ since during freeze protection, it was turning on the heater!! I understand with this setting, if we want spa mode (heated spa), then I’ll need to go in the app and turn on ‘spa’ and then ‘heater’.
- Note: In the past (with old settings) , sometimes the heater came on for a few mins and then stopped - if this happens again, we will investigate further. For now, we have increased pump RPM to 3000 for spa mode hoping that may help (at least it’ll heat it up faster).
- We don’t have a side remote control - using app is fine.
- Q: In the ‘circuits needing high speed pump’, I’ve added ‘pool high’ and ‘pool low’ - should I add ‘spa’ here too ?
- Q: Since ‘pool high’ is a generic circuit, does it know to do the right thing (it’s not configurable so it depends on how the system is setup) - i.e. spillway + run pool pump on high speed.
