So I've been having problems with my Hayward SP0710X32 valve, which is probably 15 years old. It was leaking out the waste line, so I figured I'd replace the spider gasket, but I found several of the internal plastic walls/diverters are warped, and one is cracked where it holds the gasket. I went ahead and replaced the gasket and then the handle spring because it wasn't turning easily. Well, now it leaks out around the center of the handle when in filter mode. It figures. So in addition to an internal defect, the handle assembly leaks so I'm just going to chuck it and get a new one.:?
I can have a direct exact replacement valve shipped to my house in a couple days, and I am just wondering how hard is it to take off the old one and put in the new? For example, I know how to take all the fittings off and everything, but is there any step-by-step guide, like drain the sand filter first, and do this to prevent leaks, etc.? I'm handy enough I can do things like this myself, but this is new to me and I'd prefer not to wing it...or should I call the pool store for service?
Thanks for any advice.
