- May 23, 2015
- 25,794
- Plaster
- Pentair Intellichlor IC-60
So, for S*#$& and giggles I took a water sample to Leslie's to compare to my testing. Everything seemed relatively similar with the exception of the CH. They came up with 170 whilst I turned out a 425, down from a 450 a couple of days ago. I was curious as to what our tap water CH is so I tested it and it came in at 175. Previous Leslie tests show anywhere from 250-530 (I wonder what the TF100 test kit would have come up with?) Just to make sure I'm doing it correctly I'm filling to the 10ml line with pool water, adding 10 drops of 10, 3 drops of 11L, and counting drops of 12 until red turns blue and then multiply that number into 25.
I decided that 80 to 90 for the CYA was still too high so I'm doing one more partial to drop that number. I'm hoping to have the rest of my kit by the end of today so I can slam the snot out of this puppy. I talked to a pool service person today--an acquaintance of the family--to see if he could take care of the pool while I'm working this summer. He mentioned that I need to check the TDS because that could inhibit the chems from taking affect. Also, he said be careful about using liquid chl because its only 10% chl and the rest is filler which contributes to raising the TDS. It was my understanding that it's just water and chl, am I mistaken? He recommended something stronger, but the stronger chl has either calcium or cya, right?
Oi. So much bad information.
TDS is total dissolved solids which will NOT inhibit chemicals. It's simply a measure of all the conductive ionic species in water.
LC is sodium hypochlorite and water. The process of manufacturing it can sometimes lead to excess lye (sodium hydroxide) in the solution which is what typically causes the pH to rise upon adding LC to water. The final result of all chlorine reactions on water is for it to eventually become chloride (aka, salt). So all forms of chlorine eventually add your salt levels.
Solid forms of chlorine are dichlor, trichlor and calcium hypochlorite. The former two add CYA to the water and the later raises your CH.
Oh, and yes, you're doing the CH test right and you can count on every pool store to get CH wrong 99.9% of the time.
