Hello everyone,
I'm new here and just bought my first 27' vogue panache aluminium and resin above ground pool. My installer dug the hole and is supposed to put the pool in tomorrow. He had to dig 2' 8" out of a small slope on one side and around the pool it tapers off to nothing on the other side.
I have a few questions is it ok to back fill at the level of 2'8" and tapers down to about 4-5" on the opposite side once the pool is filled with water? I live in Ohio and have dirt/ clay back fill so it will compact well. Or is 2' 8" to high to back fill? When I do backfill should input anything between the the dirt and aluminum walls? I.E. plastic, roofing tar, or flex seal?
Last should I be installing drain tile around the pool?
Thanks in advance!
Thanks in advance!
