I don't know where to start. I have black spots that I need help identifying. I live in Hollister, CA. My pool is 24,000 gallons. We had black algae 10 years ago and I got rid of the visible algae with help from Leslie’s. Unfortunately the method they told me to use raised the copper and CYA levels in the water. The CYA is still high. I know the roots persist. I think the previous owner had black algae originally because he left some black algaecide here when they sold us the house in 2009. I had water circulation problems for awhile starting about a year ago when I had to replace the pump and the filter. I now have those figured out. We started using well water 2 1/2 years ago. When our well was drilled the manganese level was quite high at .452 mg/L. Every time I topped off the pool afterwards, the water would be clear green for a few days. I have read that the combination of iron and manganese can do that. We also have a lot of iron in the water. We had a lot of rain this last year, which may have increased it. The black spots started showing up the end of May when I started topping off the pool every day and there are more all the time. I now have a filter that pretty much eliminates the metals in the well water before it goes into the pool so the water no longer turns green. I have used Jack’s Stain ID Kit on a step of the pool and got clear results. All 4 tests yielded positive results except number 2. On number 1 and number 4 spots, the area actually initially turned dark gray, then cleared eventually. Chlorine (I use power powder plus - I know, I know) and black algaecide containing copper have not removed the black spots. I have turquoise staining which I am sure is due to copper and I also have a few iron stains. A wire brush does not touch the black spots, nor does rubbing a chlorine tablet on them. I have gone from thinking they are black algae to thinking they are metal stains and have gone back and forth treating each, probably making both worse in the process. I have used the cu lator stain removal kit and it does great on the turquoise stains, nothing on the black stains. I have tons of photos I could post. I took these close up ones today of spots on the wall of the pool. They are all taken of the same spot, though not the exact same angle. The first one shows the black spots, the second one shows how they turned brown or green after I used pumice on them and the third one shows them after I then also scrubbed them a chlorine puck. Thank you for any suggestions. I think they are probably black algae at this point, but I know I also have some metal stains and I don't know what to do next.
