Hello, Im new here and have no pool repair man in my area that can help me fix my pool issue, so I will
need to fix myself and needed advice
Thank you is advance
The Pool is 15x30x 52 and its a above pool with 3 side buttress on each side
the pool is 7 + year old
the bottom had blue styrofoam and under the styrofoam was fine crush, there was cove all around the pool on top
of blue styrofoam.
My problem:
Over the year the sides of the pool got wider because the block that was under the buttress broke in haft
and sinked
We also needed to change the liner because its been over 7 year r.
As I cut the liner, found that it was hard and cracking in some place, I guess it needed to be changed.
But now I'm face with the buttress not been even and needed to added stronger concrete plates. and straighten them out 90 Degrees
1. those metal plate buttress inside the pool that where pushed up because the concrete plate broke, do they need to be buried in the crush then
masonry sand. should I put something the the metal plate to protect the bottom liner of the pool?
2. There was blue styrofoam, should I replace it with masonry sand ( 2 inch) then Armor shield /Gorilla Pad/ Rhino pad protect liner
Thank you for all your help
A desperate man trying to to make his wife happy
Im sure I will have more questions
of blue styrofoam.
My problem:
and sinked
