Hello, thanks for having me. I put in a concrete pool last year (Apr 2018) with a salt system and have been pretty pleased with it. Only thing I noticed was the surface being a little rough. We followed the PB instructions and brushed it frequently. I also chased my tail with keeping the PH down and adding muriatic acid on a regular basis. After opening this year all the areas that were under water are even worse with roughness.
I have read several posts on here about potential calcium issues and notice that my vacuum filter has quite a bit of white "crystals" in it after running a cycle and assuming these are calcium, but not sure. I have the chemical levels balanced and going to try and keep brushing to see if that improves the surface of the plaster. I am opened to any other comments for me to verify that this is in-fact calcium. I believe I saw if I put acid directly on the crystals and they bubble this is a good test??
Anyway, nice to virtually meet all of you and thanks in advance for any help. I will also share any experiences I have if it can help others.
Pool is 19k gallons, built by Blue Haven Pools
