So the pentair rep showed up and replaced the cracked pump casing under 3 year warranty today. I told him the pump cracked when It was in spa mode, so please test that before you leave. Well the pumps ran, but when we shut off the spa booster pump water sprayed out of the vents onto the heater and now the heater trips the main Pool GFCI breaker. This less than 3 year old pool / spa has sprayed water onto the heater every time the spa booster pump runs and never trip the breaker until now. Fortunately the rep saw this and said he can fix it but the vents need to be fixed first. Also he said the GFCI breaker is not supposed to be in my main house breaker panel, it is supposed to be in the pump controller and used for the pumps only. The pool builder came out immediately and cut the vents put a 90 elboe on them facing away from heater now. He told me the GFCI breaker in the main panel is perfectly OK. Do I need to be concerned? I think I need the GFCI there because the power goes to Pump Panel, and the Electrician installed a breaker in the pump panel and it to the Pool room.
