I’ve got a HiNRG 175 heater
Its giving a F2 fault. I’ve turned off the power & rebooted, my water temp is only 20 degrees, have water flow, so not sure what else to try....
I’m told “F2 fault usually leads to High Limit switches.
Often they will fail intermittently, with power on/off clearing the fault, eventually you will be locked in F2.”
Any tips on what else I should try to fix this, short of getting a technician out
