- Feb 5, 2018
- 374
- Vinyl
- CircuPool RJ-60 Plus
The previous season was the first full season using the TFP method and it worked very well for me. I have some trips planned and will be away during pool season. I have a Pentair 320 chlorinator and am considering using it while away. I noticed there is no check valve between the chlorinator and the heater. I was going to use the Pentair R172288 valve recommended to be used with this chlorinator but now have concerns with flow reduction at lower pump speeds since I added a VS pump. Would a Jandy or other type check valve be a better choice? Maybe I should just give up using the chlorinator and tie a floater in the middle of the pool while gone for a week?
