I've got a new pool and spa. It has a Hayward 500 BTU heater running on propane. The pump is a Tristar VS 950 omni variable speed pump. To keep the noise down, I usually run it around 70-80%.
Today we started up the heater with the pump running at 80%. It worked fine for about 10 minutes then it started popping and rattling and eventually shut off with code HS. I understand that this happened because the heater wasn't getting enough flow and water inside of started to boil. I ran the heater at 85% and it worked for a while. Then when I slowed it back down to 80% the popping started and the heater shut down. This is with the valves configured to "spa mode" where it is just circulating water through the spa.
Then I tried it in "pool mode" where it is circulating water through the pool. It ran fine with the pump as low as 70% and didn't do the boiling water thing.
So I suppose the spa has more restriction in the water flow than the pool and the pump has less GPM at the same RPM.
Question - Should I expect to be able to have enough flow through my heater with that Tristar 950 pump running at only 80%? The heater manual says it requires 40 GPM. I don't know if something is wrong with my setup or if this is just how it is supposed to work.
Sal
Sal
