I live in northern NJ. I bought my home a couple of years ago and the previous owners had some solar panels to heat the pool. I would like additional heating. I use bubble wrap type cover on the pool at night and generally keep it covered when I'm not using it. I want to be able to use the pool from memorial day through end of September and have water temp be about 88F.
Every pool guy I talk to gives me different advice on heat pump vs gas heater. I have been told heat pumps are more energy efficient and cheaper to run and last much much longer. I really like that I don't have the extra complexity of having to install a gas line which can cost $2000 to $2500 for the permit plus installation. However i have been told heat pumps are more complicated to repair. They heat more slowly, they only heat water a couple of degrees and don't work if it isn't hot outside. Is this accurate?
Most contractors in NJ say that in the northeast everyone uses gas heaters and heat pumps are used more in the south. Something to do with dew point and humidity.
My preference is a heat pump to avoid the complexity of gas line. Anyone here live in the north east US and have experience with heat pumps? What do you recommend?
