I've spent a couple of days searching through many old discussions of pool heaters, and understand a lot of the ins and outs of heat pump efficiency versus quicker responsive heat when using a natural gas heater, but feel I could use a little more guidance before making a decision on the way to go here.
I live in Huntsville, Alabama, and while all of MY large trees were cut down many years ago, my pool suffers from the shade of my neighbors trees. Sun doesn't start hitting the pool from the east until 9:30am or so in summer, hits the entire pool by mid day, but by 3pm, large trees to the west are casting their shade, and by 4pm at the latest, there is no longer any sun on the pool. The pool is an 18x36 in-ground pool, about 27,000 gallons (8 feet at deep end + 8 foot wide steps at shallow end), with a diving board. I run salt water.
I bought a solar cover last summer, but have no reel at the moment. It was my job to put it on and off the pool last summer if I knew the kids or grandkids were coming over to swim. And invariably, it would have collected rain water or pollen pods or leaves that dumped into the water, requiring me to then spend time cleaning the pool. My first priority this summer is a solar cover reel of some sort, but it is complicated by the 8 foot diving board at the deep end. The "low" solar reels that will fit under a diving board are insanely priced. And to be honest, last summer, even though we were in a drought, we had a lot of cool nights, and even with the cover, the pool very rarely reached what I consider a swimmable temperature in the mid 80's. Most of the time the pool was in the 78-80 range.
My wife has terminal cancer, and I want this summer and hopefully next summer to be a great time of family get togethers, and in light of that, have told my wife that I am putting some form of pool heater in, so that we can enjoy more time with our adult children and grandkids while we (she) can. Having water at around 85F would go a long way to making folks want to hang out in the pool in the evening or afternoon.
So here is where I am. I have natural gas at the end of the house that the pool equipment is located at, but unfortunately, after talking to my utility company yesterday, my meter and the pipes cap me to pool heaters under 300K BTU's. Looking at what is out there and compatible with a salt water pool, the best I can do would be a 250K BTU Hayward pool heater. Unless I pay $400-500 to the utility company for a new meter. Plus all the other cost to replace the pipe from the meter to the rest of the house with larger pipe than the 1 1/4" that is currently leaving the meter to run to the house. It runs about 20 feet, then decreases to 3/4" iron pipe, with one branch diving into the crawlspace towards the kitchen and fireplace, while the other goes directly to an outside "gas pack" on the HVAC unit.
So, I started looking at heat pumps, and the issue there is a 140K heat pump of course costs almost $2000 more than a 250K BTU gas heater, AND right now, I have a 100A run to that end of the house with a sub panel on the end of the house for the HVAC, which has a 50A breaker, and then there is a 30A breaker to run the pool pump and other items. There is not 50-60A to spare for a heat pump unless I run another complete circuit, which involves going UP a garage wall into the attic, then DOWN an interior wall into the crawlspace, and then through the brick at the end of the house. A lot more work than the gas change probably, but doable.
No matter what I do, I will be digging trenches and relocating my pump and filter to be against the end of the house where the HVAC, gas and electrical are located. Right now they are kinda out in the yard, and are an eye sore. I've wanted to move them for years, but didn't have anything driving it before now.
But back to the heater. Without doing anything about the gas meter, I can support a 250K BTU gas heater, with just getting my HVAC guy or a plumber a couple hundred to run about 10 to 15 feet of gas pipe to it from the existing pipes that run across that end of the house from the meter in the front yard.
The question really comes down to COST of running gas versus a heat pump, if I want to have a pool be 85F rather than 78F for random afternoons that grandkids drop by, or for Saturday/Sunday afternoon get togethers with the entire family. My utility rates are:
Natural gas @ $11.07 per 1000 cubic feet, which equates to pretty much $1.107 per therm.
Electricity @ $0.11735 per kWh.
I would get a solar reel, and do my best to keep it covered at night and when not in use, but looking at heating times, we are talking 6 hours with the 250K BTU unit for an increase of 5F (80->85 degrees). With 140K BTU, you are talking about around 8 hours to make that same 5F increase.
Best I can tell, if I am doing my math right, if the pool is at "natural" temperatures, which last summer ran 78-80 with the solar cover a lot, it would cost me $5.98 and 8 hours with a heat pump go get it to the temp I want. With the gas heater (250K unit), it would take 4 hours, but cost me $14.34 in gas. If I understand the math right.
The question really is whether someone in the same vicinity of the south-eastern US can comment on their experience with a gas heater versus heat pump. I am hesitant to go with gas if it is going to add hundreds of dollars a month to our utility bill. I don't want to spend $14+ every day we want to swim. If that was just 3 times per week, it would be adding up to a lot per month. But I don't know what it would look like to use a heat pump and let it get to 85F and then just STAY AT THAT TEMP all the time, keeping the solar cover on at night and all non-use days. Would that be cheaper in the long run, even with the expense of the wiring?
Does anyone have any thoughts or guidance for me here? My wife is leaving this entire decision to heat the pool in my hands, as she knows I want to do it so we have some good family times together this year.
Thanks so much!
Jim
Thanks so much!
Jim
