- Jun 18, 2014
- 661
- Vinyl
- CircuPool RJ-60 Plus
Looking for recommendation for a 140K BTU HP (large single phase ). From looking over multiple manufactures spec sheet the efficiency are all similar (as expected). Are there mfg that are more DIY install accepting? Warranty for DIY install? Any brands more or less reliable than others or last longer? It looks like R410A is going to be phased out to R32. Doesn't look like there are many domestic R32 HP, they mainly look to be imported. R32 should be a little more efficient, not sure if it will be significant enough to tell.
I looked at running NG when redoing the pool a few years ago, but it was going to $8K to $10K to run a line and upgrade the service to my home, so out of the budget and the running cost was about double of a HP. I ended up upsizing the electrical service to the pool, I was replacing it already, only cost more for larger wire and larger conduit.
