I've not been actively reading the forum for a while. I've gotten behind on changes in the industry, if any, which I keep hoping for but can't figure out whether it's happening or not. Specifically, I'm trying to gauge whether or not one of the main TFP tenants that differs from the "traditional" method of pool care historically, the concept that FC should be maintained at minimum 7.5% of CYA for outdoor, non saltwater pools; if that mandate is being adopted by the industry or not? When I do a Google search, I find some pool stores and pool care professionals, online companies, specifically in Florida that are now talking about the need for maintaining this ratio and they cite the exact FC/CYA chart that originated with Ben Powell and perfected and published on this site. I also found and read a few state health department guidelines that also seem to indicate higher FC levels than what used to be the standard for a separate category called "stabilized" pools (the state of GA is the one I looked at most closely); even though they did not require a ratio or a percentage. They simply require a higher FC minimum and allow a higher maximum for what is labeled "stabilized" pools. I think the chart I saw first had a box that showed no higher than 5, but then stated, except for the case below; that case being the category called "stabilized" pools.
So on the one hand, it looks like the official regulators in the industry...state and local health departments, are starting to adopt this requirement, at least in part, to maintain healthful and safe pools; but on the other hand, I still read chemical company labels that give out all kinds of misleading and just plain wrong information like we're used to seeing. I just bought a few jugs of Kik brand liquid chlorine at 10%; manufactured June 2017. It seems to be a very good product, as it is raising my FC slightly above what I expect for the ounces added; however, it gives that old recommendation of a crazy-low FC level and does not allow for higher levels at higher levels of CYA. In fact, it's just the opposite, stating that FC should never be above 3, and that one should not go in a pool that has FC over 3.
So what gives? Those of you who keep up with the industry and whether or not BBB/TFPs efforts are getting in to the mainstream. Is it happening? Is the industry ever going to try and publish the truth about proper sanitation of outdoor pools? If someone has access to some recent articles or other information, please leave a link. This is something that has fascinated me ever since a pool store associate told me that I should no longer add stabilized chlorine to my pool because my CYA was 68; and I went home and found TFP, because I didn't understand how my CYA got to be 68 when I had not added CYA (or at least I didn't know I had added it). I started reading TFP pool school and couldn't believe that an industry had served us so poorly for so long and had not been forced to straighten up its act.
