Hayward XStream Replacement
Aug 30, 2017
51
wauconda il
Last year I replaced the pump for my Hayward Xstream 150 Sq Ft System.
This year the locking ring broke, boy was I surprised when I found out why the pool was losing water!
I'm looking at a new system, I could replace with the same but is there a better setup for a 150-200 sq ft filtration system?
Good morning! Did you make a selection yet? While there are several single cart systems out there, some may say go with something larger if you have room for it on the pad. Larger filters generally require less cleaning, but that's totally up to you.
