I just installed a new Hayward VS super pump today as my old pump was finished. Electrical and plumbing all hooked up but when I flip the switch for power it sometimes starts and sometimes does not. When it does start it goes to “priming” mode and counts down from 8 minutes. It’s gotten to about 2 minutes and then it shuts off, done. Can’t turn it back on.
It does prime itself and the pressure on the filter gets to abou normal. 18 psi and with old pump would be about 20 psi.
Any idea why it’s shutting itself off? Is it electrical? I have a heater hooked up to the same panel outside and it still has power and will come on. The pump is a separate 220 switch on the panel.
The wires from the panel to the pump are pretty old. Should I switch those out?
I’m pretty stuck here. Just got a new liner on Wednesday but now my water has just been sitting there....
Any help is appreciated!!
I’ve never had a VS pump or Hayward but my guess is that it should come right on once the power is turned on right?
