This pump was installed in 2020 and hasn’t given me an issue until now when I went to open the pool today.
I was first greeted with this message:
“check system display comm failed - check wiring between display and drive”
I did some digging and called the dealer I got it from and they said to try a new display so I went and spent $400 on that (they said they’d take it back if it didn’t fix it). I get home and plug it in and the exact same error displays.
From here I pull the cover off where the wiring and other boards are and quickly see I had some definite corrosion and water intrusion.
I checked all my cables and I’m getting 12v out to the display as it should, but it seems like something else got fried….
I’m at a bit of a loss on where to begin or if there is anything I can do beyond this? I’m not seeing any replacement boards or pcb (I’m no electrical engineer here so excuse my terminology). So I was hoping to tap into the brains here to see if you have any further trouble shooting I could perform?
Secondary question is there anyway to jump the thing to just get it working at a single speed for now?
