I had a loose hot leg and it burnt terminal block, and capacitor. I can fin the capacitor but unable to find a replacement for the terminal block. The block is made in Italy, which I found online however minimum order is 500 pcs. I spoke with product support and the do not support the motor? I’m share I could use a standard terminal block but I would need a wiring diagram for the 115vlt, capacitor, with temperature fuse.
