Hello,
I am replacing a Hayward single-speed pump (SPX4020X25NS) with a 2-Speed (SP3220X25). I have discovered that the old pump unions have a plumbing connection that uses a pressure ring-type screw-on nut, which has been replace by a simple sleeve and nut-type union.
My problem being - on the pump input side, the old union kits are pvc cemented in line with an automated valve and a check valve, with no room to splice in any 2" PVC extension. I would have to replace the entire segment that includes automated valve, check valve and union.
So, I am inquiring whether there is a conversion joint that matches the old style pressure nut to the screw-on union connector ?
Jeff
Jeff
