When I had my pool built in 2015 I never thought I would want or need any automation. It’s just a basic rectangular in ground vinyl liner pool with no spa or other features. I have all Hayward equipment to include to a variable speed pump model SP3200VSP and an AquaRite Pro SWG. Well over time I added a Hayward 140k heat pump and a Cat 1000 pH controller with a Stenner pump/tank. My equipment pad is outside the pool area in the back of the yard next to a small shed for pool stuff. I was thinking how nice it would be to check on things remotely to make sure there is enough flow for the SWG and heater without having to go back there. Then I came across Hayward’s fairly new Omnihub pool and spa controller which was exactly what I was looking for plus the ability to change heater temp, SWG output, pump speed, etc. from a smart phone or tablet. They are touting this as an easy retrofit to any existing pool equipment. So before I dropped $800, I contacted Hayward to make sure it would control my equipment. Well what do you know, their retrofit solution to automation will not work with my pump. A 3 year old Hayward vsp can not be controlled by Omni. Turns out reading my pump manual the SP3200vsp (the one with control the display) can not be automated but the SP3200vspnd (no display) can. Can someone please tell me why? If I unplug the removable control panel and open wiring the cover it looks identical to the one with out the display for automation to include dip switches and low voltage connections. According to the Omnihub install directions I can use a relay but the pump must be set to one speed and then it is simply an on/off control, which to me defeats the purpose of a vsp.
