Ok I have searched and read all the previous threads about this issue. I just want see if there is anything else I can do before I replace the board. It of course started with replacing the cell. Then the High Salt and AMP warning came. I took the board out and found the burned solder joint. Soldered the joint and still getting the High Salt/AMP error. I had to resort to putting a hair dryer on the cell to get it warm enough to test just now since it is 48 degrees. after about 10 min the cell was allowed it to turn on.
What I have...
What I found...
I am thinking that the trace is burnt beyond use now.... Can I just solder a wire between these 5 solder joints? It looks like those are the only pins in that trace...
This is what it is doing now that I had the cell warm enough to turn on and after 20 seconds.
What I have...
What I found...
