Hayward Heater Small Leak and Won't Fire
dailygenesis
243
Oklahoma City
Hello there. I have just noticed my Hayward H500FDN heater was not firing and went out to check and it has a bit of a slow, dripping leak at the front left bottom and mid-right bottom of the unit. I took off the front panel and can't see anything leaking in there but that's as far as I have gone.
Based on what I have read on this forum, it seems likely this could be the heat exchanger and that replacing the unit might be my only course of action. But, I wanted to check here to see:
1) Is there anything else I could/should do or check on my own?
2) Is it possible to get the heater to fire and run even with the leak, or will the leak always prevent it from firing (I guess what I'm asking is whether the leak and the ignition failure are related or separate issues)?
Thank you!
Disassemble the heater to where you can observe where the leak is coming from.
Depends where the leak is, where the water is flowing to, and the volume of the leak.
The heater may fire with a small leak and any water will be vaporized in the exhaust.
A larger leak will put the flame out and not let the heater run.
This may be a little more than I can take on, but I will look into it. Do I need to disconnect power, etc. before doing this disassembling? I assume not because it will need to be running to see where the leak is.
You don't need the heater running to see where the leak is.
You just need water flowing through the heat exchanger. You can often see that without the heater firing.
It is always good to trip the circuit breaker before working on equipment.
Oh, sorry yes I just meant I would need water flowing not the heater running. I believe the heater is on the same breaker with the automation system so if I trip that I guess I would just run the pump manually. But I've never done that before either, so a lot to figure out. Or I guess I could disconnect the wires for the heater from the breaker.
You really do not want other devices being on the same breaker as the automation.
Do you want to lose your automation because the heater has an electrical problem tripping the breaker?
I'm sure I don't but this is the way the installer set it up and I don't believe there is another breaker in there to use. I would have to get an additional breaker added.
I wasn't able to get around to trying to diagnose this myself. But I had a guy from a pool company I like out (my original pool builder has not been good to work with in support) and he showed me where there is a lot of corrosion around the heat exchanger and water leaking out from there. So, it seems that it's going to need a replacement.
This new company I'm working with is a Pentair shop and so they are recommending the Pentair 460736 400K Ng Mastertemp Heater. They also said I could go with the 250K unit, but I'm inclined to spend the extra money for the faster heating. We use our pool heater a lot for the spa and to heat the pool and extend the season, so I want something that is going to work and work well.
Any thoughts on this recommendation? Any considerations I should keep in mind with this Pentair unit? Any issues I will potentially have working the Hayward controller and Pentair heater together?
Also, I am planning to have them plumb in a heater bypass when they do the work. Someone on this forum recommended that a while back. Is that a good idea?
@ajw22
Pentair MasterTemp is a fine heater.
Thank you. I'm a little confused where the article mentions the Pentair Automatic Bypass. Are they saying that with a Pentair heater this is better to use instead of a manual bypass? Or would you have both a manual bypass and this automatic bypass?
The Pentair automatic bypass is just putting an actuator on the manual bypass valve. You can't do that with eCommand automattionm.
Ah ok. I thought it was an actuator somehow controlled by the heater itself. If it relies on control from the automation system then yeah that makes sense.
It is a bit complicated but the bypass actuator can be controlled by the heater if the heater is operated standalone.
If your eCommand controls the heater, it will power down the heater before the actuator can open the bypass.
So with your setup you cannot use it.
