I'm calling this part II because what brought me hear was a Hayward Ignition Failure thread posted by user Ericky, with the same title, a few years ago. My situation is a bit different.
Heaters about 5 years old, hardly ever used. In the first 2 years I got an "IF". It would light upm ignite but immediate shutoff, try it 2 more times than quit with an IF code. I did a bit of research, but I had never worked on a pool heater before so I assumed it was similar to a water heater and had a bad thremocouple. Well Hayward doesn't use a thermocouple, they use a flame sensor (technically I am uncertain how their flame sensor works from a physics standpoint, it only seems to have one electrical terminal, unless the casing mount is a ground reference.)
Anyway, I replaced the flame sensor and it worked for the infrequent times I used it the following 2 years.
Fast forward to a few months back, I noticed an IF error code again. I'm finally getting around to it.
Same story: Fan turns on, Gas ignites, heats pours out for a few seconds, shuts off. Retries three times. This time I replaced the flame sensor but it hasn't made a difference. Flames still shut off after a few seconds ignition.
I do not have time to figure this out so I need to get some expert advice. Hoping it is a simple issue. I have a voltmeter so I can check voltages, just not certain what I want to look for.
Thanks in advance!
-John
Thanks in advance!
-John
